ACS 4.1 problem
I'm setting up ACS 4.1 and I'm running into a problemw ith command authorization on a PIX firewall. After all the configs on the PIX and setting up the group and device on the ACS 4.1 server, I'm able to login to the PIX with my windows username/password. Once I'm in, I'm able to get into enable mode (with the enable password), but once I'm in enable mode I can't type any command...I get command authorization failed. I check the ACS server and I see myself sucesfully log in in the logs, and then in the failure logs I see this:
04/13/2008 09:11:08 Author failed enable_15 Default Group 0.0.0.0 (Default) .. User unknown ..
Why would it try to authenticate enable_15?
What part of the config on the acs server am I missing?
Also...if I add an internal user in ACS named enable_15 and add him to the right group, everything works fine...but I don't think I should have to do that.
