http not optimizing well
Apr 13th, 2008
Hi all,
does anyone have an idea how to optimize web traffic with waas. the wae i have installed have a 4.09 image loaded on it. It optimizes email, printing wafs and other traffic very well but web and oracle traffic hardly get 20% optimization. The link is a satellite link with high latency. could it be the image?
Overall Rating: 5 (2 ratings)
Zach Seils Mon, 04/14/2008 - 13:07
  • Cisco Employee,
Oladotun,
Do you see the HTTP connections with full optimization applied (F,F,F,F)?
Zach
dot10000000000 Mon, 04/14/2008 - 23:48
Zach,
Yes it has full optimzation applied. could it be the image? The image on the wae is 4.09b. maybe a 4.017 image will work better than the current one on the box.
Regards.
dotun.
Zach Seils Wed, 04/16/2008 - 20:29
  • Cisco Employee,
Upgrading to 4.0.17 will provide numerous fixes, so it's worth the effort.
Can you upgrade and see if the problem persists?
Zach
dot10000000000 Mon, 05/05/2008 - 00:45
upgrading the image to 4.0.17 does fix the http optimization and sql problem. the image works very well for me.
Regards.
dotun
