cat 2960
Apr 13th, 2008
I will order CAT 2960 switches "Cisco Catalyst 2960-24TT-L". I check the spec of ethernet switch from following link:
I guess the "switch fabric" to be the "back plate switching"
I do not know what the "Mpps" stand for and the function. where can I find it?
e.g. Catalyst 2960PD-8TT-L: 2.7 Mpps
Overall Rating: 3 (2 ratings)
anitachoi3 Sun, 04/13/2008 - 07:40
it means that "Catalyst 2960-24TT-L: 6.5 Mpps" should have 6.5 x 64 = 416 M (b/w per port). The total "back plate" should be 10G. Is it correct?
Istvan_Rabai Sun, 04/20/2008 - 08:09
Hi Anita,
I was looking for the exact definition of the "Forwarding Rate" but I could not find it anywhere.
If someone has a good definition for it can you please share it with us.
Thank you:
Sushil Kumar Katre Sun, 04/20/2008 - 23:33
Forwarding rate is the number of packets that can be pushed/routed through the switch in a second. Unit - Mpps.
The backplane is a set of physical connections (traces) and/or silicon which provide connectivity between line cards or interfaces in case of a non-modular switch. Unit - Gbps/Tbps.
There is another term associated with switches "non-blocking/blocking switches" I thought would be worth mentioning - It's a popular marketing term that refers broadly to the ability of a switch to handle independent packets simultaneously. For example, suppose a packet is traveling from port A to port B when a new packet arrives on port C. A ``nonblocking'' switch will accept and process the new packet before it completes the previous transfer. If the new packet is destined for port A or B (which are currently busy), the switch will queue the incoming packet until the destination port becomes available. Of course, the queue is finite; even a nonblocking switch must eventually reject packets (i.e., must eventually block).
There is a good link on this -
>> Sushil
