Multiple NAT AND PAT
Apr 13th, 2008
If you have only 1 public address can you NAT and PAT to 2 servers/PC's on the same port or do you need more public addresses.
For example to FTP servers on the LAN with a single IP address on the outside.
Richard
Overall Rating: 2 (1 ratings)
thotsaphon Sun, 04/13/2008 - 07:41
Hi Richard,
You meant that 1 public ip address can be used for 2 private ip addresses with the same port. Right?
If that's what you asked for. It's hard for the router to know what's exactly ip address to do PAT functions when the traffics from the outside are going to go to the inside.
Actually the router will not allow you to that though.So you need to have another one public ip address to beat this requirement.
Hopes this helps
Thot
CSCO10663272 Sun, 04/13/2008 - 18:55
Hi Thot
Thanks for the response thats what I thought, just wanted to hear it form somebody else.
Richard
