mohammedmahmoud Sun, 04/13/2008 - 11:35
  • Green, 3000 points or more
To check the last time a topology change has occurred then please use "show spanning-tree vlan x detail":
Rack1SW1#sh spanning-tree vlan 1 detail
VLAN0001 is executing the ieee compatible Spanning Tree protocol
Bridge Identifier has priority 32768, sysid 1, address 001b.90b4.6900
Configured hello time 2, max age 20, forward delay 15
Current root has priority 32769, address 001b.904f.ec00
Root port is 15 (FastEthernet0/13), cost of root path is 19
Topology change flag not set, detected flag not set
Number of topology changes 15 last change occurred 00:00:55 ago from FastEthernet0/1
Times: hold 1, topology change 35, notification 2
hello 2, max age 20, forward delay 15
Timers: hello 0, topology change 0, notification 0, aging 300
BR,
Mohammed Mahmoud.
rsamuel708 Sun, 04/13/2008 - 16:49
Can you tell me what version of code did the number of topology changes including the last change time begin? I have a 3550 running the following code and it gives me the following output:
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5.4)WC(1), MAINTENANCE INTERIM SOFTWARE
switch#sho span vlan 1 det
% Invalid input detected at '^' marker.
Thanks.
/rls
mohammedmahmoud Mon, 04/14/2008 - 00:43
The output i've posted is from a 3560 running "c3560-advipservicesk9-mz.122-25.SEE3.bin", i've tried this on one of my 3500XL and yes it seems that it doesn't support this command, you can try and do an IOS upgrade, but i can't assure you that it will support this command.
BR,
Mohammed Mahmoud.
