ISDN BRI and Bintec Router and ISDN Modem
Apr 13th, 2008
I looking for some help on configuring a Cisco Router that is connected to a Bintec Router connected to the Cisco Router via ISDN BRI. The connection is coming up as Multiple Frame Established but as outgoing call from the router to connect to a remote customer through the Cisco VoIP Router will not connect.
The floowing is the path:
Telco---isdn BRI----Cisco Router---isdn BRI----Bintec Router.
Below is a debug of the call:
*Apr 11 22:59:31.011: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8 callref = 0x63
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x83
Preferred, Any B-channel
Calling Party Number i = 0x81, '4444'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '8030757744912'
High Layer Compat i = 0x9181
*Apr 11 22:59:35.061: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x63
Cause i = 0x80E6 - Recovery on timer expiry
*Apr 11 22:59:35.061: ISDN BR0/1/0 **ERROR**: L3_BadPeerMsg: event 0x5A cr 0xE3 callid 0x0
Also the same router is connected to a ISDN Modem via a BRI used to dial out to customers too. The connection only has layer 1 and Layer 2 is TEI-Assigned.
Attached is the configuration Currently on the router. It is located in Germany.
Can anyone suggest changes to make the Bintec able to dial out and the ISDM PC Modem. This router is used for Cisco IP Phones which is working properly.
Any configuration help would be appreciated.
paolo bevilacqua Mon, 04/14/2008 - 02:35
  • Hall of Fame,
    Founding Member
Hi, the strange thing is that there is no outbound call from cisco. Which exact IOS are you using ?
