Problem with TCL scripts
philongcompany
Hello
In attachment is our cisco 2821 config. But i can not get welcome message from our site call to PSTN line.
Everybody please help
paolo bevilacqua
Hi, show tech support is too verbose for forum purposes. Just include output of "show run" and "debug voip application script" when calling, for the latter you need also "term mon".
In attachment is our "show run"
When I using "debug voip application script" it only show "voip application script debugging is on"
please help me
Thanks and best regards
Are you using fxo ports and you don't have "connection plar opx" for them ?
You also need "incoming called-number" under the DP that starts the service. The service configuration itself is also incomplete, miss a lot of parameters, once the scripts kick in, debug will tell you which ones.
Hello
Before I using fxo but now I change all to voice ip. I try to put "incoming called-number" but problem not solved
Please help me
