04-13-2008 10:44 PM - edited 03-15-2019 10:02 AM
Dear Experts,
Can I increase time between digits (disconnect time) .
That will be if dialing any external number (PSTN Number) such as 00962777556669 and I stop dial the digits after 7 digits (dial 009627 and stop) so I will get a disconnect message. So how I can increase this time??
04-14-2008 02:56 AM
Hi, you have asked this in otheer forum as well, please contain posts to a single place.
Anyway, you need to mention what exact system do you have.
04-14-2008 06:09 AM
This option is specified using the "timeouts interdigit" command under "Telephony Service"
The default is 10 seconds.
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/dial_peer/dp_plan.html
04-14-2008 07:26 AM
Hello Islam,
I have to add to please beware when changing your inter digit timeout, especially when working with international dian plans.
Justin
