ASA inside Networks
Apr 14th, 2008
my ASA is droping tcp packets from the inside networks during communication between inside hosts - because inside router sends tcp ack directly to the client,and second syn packet from the client is droped by the ASA because there was no ack .... did anyone know how i can disable the tcp inspection for inside networks on the asa ?
mchin345 Fri, 04/18/2008 - 06:07
  • Silver, 250 points or more
If you disable TCP inspection engines with the no inspect tcp command, outbound users can start connections only in passive mode, and all inbound TCP is disabled.
