%DUAL-5-NBRCHANGE message
Apr 14th, 2008
I have 3 routers connected via FR ( hub and spoke topology, R2-hub, R1 and R3 are spokes). I see error message at R3 -
%DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 183.1.123.1 (Serial0/0/1) is down: retry limit exceeded
Which reason of that message can be and where search mistake?
R1
interface Serial0/0
ip address 183.1.123.1 255.255.255.0
encapsulation frame-relay
frame-relay map ip 183.1.123.2 102 broadcast
frame-relay map ip 183.1.123.3 102
no frame-relay inverse-arp
router eigrp 100
network 150.1.1.1 0.0.0.0
network 183.1.17.1 0.0.0.0
network 183.1.123.1 0.0.0.0
no auto-summary
eigrp router-id 150.1.1.1
Rack1R1#sh ip eigrp ne
IP-EIGRP neighbors for process 100
H Address Interface Hold Uptime SRTT RTO Q Seq
(sec) (ms) Cnt Num
1 183.1.17.7 Fa0/0 11 14:10:45 616 3696 0 13
0 183.1.123.2 Se0/0 156 14:15:12 49 294 0 37
R2
interface Serial0/0
ip address 183.1.123.2 255.255.255.0
no ip split-horizon eigrp 100
no fair-queue
frame-relay map ip 183.1.123.1 201 broadcast
frame-relay map ip 183.1.123.3 203 broadcast
router eigrp 100
network 150.1.2.2 0.0.0.0
network 183.1.28.2 0.0.0.0
network 183.1.123.2 0.0.0.0
no auto-summary
eigrp router-id 150.1.2.2
Rack1R2#sh ip eigrp ne
(sec) (ms) Cnt Num
2 183.1.123.3 Se0/0 153 14:15:45 48 288 0 208
1 183.1.123.1 Se0/0 135 14:16:54 49 294 0 24
0 183.1.28.8 Fa0/0 13 14:24:26 12 200 0 20
rmv72 Mon, 04/14/2008 - 00:51
R3
interface Serial0/0/0
ip address 183.1.0.3 255.255.255.0
ip ospf network broadcast
ip ospf dead-interval minimal hello-multiplier 3
ip ospf priority 0
clockrate 2000000
frame-relay map ip 183.1.0.4 304
frame-relay map ip 183.1.0.5 304 broadcast
router eigrp 100
redistribute connected metric 10000 100 255 1 1500 route-map VLAN33
network 150.1.3.3 0.0.0.0
network 183.1.123.3 0.0.0.0
no auto-summary
eigrp router-id 150.1.3.3
Rack1R3# sh ip eigrp ne
(sec) (ms) Cnt Num
0 183.1.123.2 Se0/0/1 134 13:59:32 50 300 0 37
Rack1R3#
*Apr 14 07:29:07.575: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 183.1.123.1 (Serial0/0/1) is up: new adjacency
Rack1R3#
*Apr 14 07:32:12.087: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 183.1.123.1 (Serial0/0/1) is down: retry limit exceeded
Rack1R3#
*Apr 14 07:32:53.659: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 183.1.123.1 (Serial0/0/1) is up: new adjacency
Rack1R3#
*Apr 14 07:35:58.175: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 183.1.123.1 (Serial0/0/1) is down: retry limit exceeded
Rack1R3#
*Apr 14 07:36:25.239: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 183.1.123.1 (Serial0/0/1) is up: new adjacency
Rack1R3#
*Apr 14 07:39:29.751: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 183.1.123.1 (Serial0/0/1) is down: retry limit exceeded
Rack1R3#
*Apr 14 07:40:10.123: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 183.1.123.1 (Serial0/0/1) is up: new adjacency
Rack1R3#
Rack1R3#
Rack1R3#
(sec) (ms) Cnt Num
1 183.1.123.1 Se0/0/1 167 00:01:07 1 5000 1 0
0 183.1.123.2 Se0/0/1 166 14:12:06 50 300 0 37
Rack1R3#
rmv72 Mon, 04/14/2008 - 01:25
Rack1R3#ping 224.0.0.10
Sending 1, 100-byte ICMP Echos to 224.0.0.10, timeout is 2 seconds:
Reply to request 0 from 150.1.3.3, 1 ms
Reply to request 0 from 183.1.123.2, 88 ms
I don't have reply from 183.1.123.1 ( R1)
But if i do it from 183.1.123.1 i have reply from R2 and R3=
Rack1R1#ping 224.0.0.10
Reply to request 0 from 183.1.17.7, 1 ms
Reply to request 0 from 183.1.123.3, 180 ms
Reply to request 0 from 183.1.123.2, 140 ms
Reply to request 0 from 183.1.123.2, 128 ms
Reply to request 0 from 150.1.1.1, 1 ms
Istvan_Rabai Mon, 04/14/2008 - 09:56
  • Gold, 750 points or more
Hi Mike,
For the configuration to work you don't need to configure frame-relay mapping between the spoke routers R1 and R3:
R1
interface Serial0/0
frame-relay map ip 183.1.123.3 102 - this mapping is not needed (on R3 not needed either).
You probably have the symmetrical config on R3, but it is not required either.
The spoke routers each need to build up the neighbor relationship with the hub router R2 but not between the spoke routers R1 - R3.
Remove these frame-relay map commands.
Routers R1 and R3 will learn each other's routes through R2 anyway, due to the "no ip split-horizon eigrp 100" command that you applied rightly on R2.
Cheers:
Istvan
rmv72 Tue, 04/15/2008 - 01:26
Hi Istvan!
But without that mapping i don't have connectivity between R1 and R3.
rmv72 Tue, 04/15/2008 - 01:35
Several words from theory-
From the output of the show command, the SRTT is at 0 ms, the retransmission timeout (RTO) timer is at 5000 ms, and the Q count is at 4 and is not decrementing. These three numbers give the biggest clue that this is a unidirectional link problem. The following is the meaning of SRTT, RTO, and Q count:
Smooth round-trip time (SRTT)-The number of milliseconds it takes for an EIGRP packet to be sent to this neighbor and for the local router to receive an acknowledgment of that packet
Retransmission timeout (RTO), in milliseconds-The amount of time that the software waits before retransmitting a packet from the retransmission queue to a neighbor
Q count-The number of EIGRP packets (Update, Query, and Reply) that the software is waiting to send
Referring to Example 7-1, the fact that the SRTT timer is 0 indicates that no acknowledge-ment packets are being received. The Q count is not decrementing, which indicates that the router is trying to send EIGRP packets but no acknowledgement is being received. RTR B will retry 16 times to resend the packet; eventually, RTR B will reset the neighbor relationship with the log indicating RETRY LIMIT EXCEEDED, and the process starts again. Also, keep in mind that the 16 times retransmission of the same packet is done using unicast, not multicast. Therefore, the RETRY LIMIT EXCEEDED message indicates a problem with transmitting unicast packets over the link, and this is most likely a Layer 1 or Layer 2 problem.
The solution to this problem is to troubleshoot from a Layer 2 perspective. In this example, a call to the WAN provider is needed to find out why the circuit from RTR B to RTR A is broken. After the link between RTR B to RTR A is fixed, the problem will be resolved.
In my case i can ping R1 from R3. Strange things.
Istvan_Rabai Tue, 04/15/2008 - 11:20
Hi Mike,
As I mentioned, you don't need direct connectivity between R1 and R3. They should be reachable for each other through R2, the hub router.
You should be able to ping between R1 and R3.
Please remove those mappings and post me the show ip routes from all three routers so I can see what happened.
Istvan
