sh cable modem ver vs. SNMP
nkrantz01
Currently we can ask our CMTS with sh cable modem XXXX.YYYY.ZZZZ to get the following information:
MAC Address
IP Address
Prim Sid
Interface
sysDescr
Upstream Power
Downstream Power
Timing Offset
Initial Timing Offset
Received Power
MAC Version
QoS Provisioned Mode
Enable DOCSIS2.0 Mode
Phy Operating Mode
Capabilities
Sid/Said Limit
Optional Filtering Support
Transmit Equalizer Support
Number of CPE IPs
CFG Max-CPE
Flaps
Errors
Stn Mtn Failures
Total US Flows
Total DS Flows
Total US Data
Total US Throughput
Total DS Data
Total DS Throughput
Active Classifiers
DSA/DSX messages
Dynamic Secret
Total Time Online
Is it possible for me to use SNMP instead and get the same data back, either from the CMTS or directly from the Cable modem. If yes, where can I find the correct SNMP OIDs?
Niclas
tstanik
Level 5
Level 5
A Management Information Base (MIB) is a collection of information that can be managed by the SNMP manager.
The objects in a MIB are organized and identified by object identifiers (OID) that are defined by the IETF and other organizations.
Here is the link for the Admission Control MIB Specifications for the Cisco CMTS :
http://www.cisco.com/en/US/docs/cable/cmts/feature/guide/ufg_adm.html#wp1230279
Also refer the below link which will helps you for the CMTS :
http://www.cisco.com/en/US/docs/cable/cmts/mib/reference/guide/ubrmib1.html#wp105407
Thanks for your reply.
What I am actually after is some kind of mapping from the sh cable modem command to a corresponding SNMP OID.
For example, this link shows us some details, but doesn't give mapping for all sh cable modem commands.
http://www.cisco.com/en/US/docs/cable/cmts/mib/reference/guide/ubrmibb.html
Anyone who know if/where more detailed information can be gathered?
Niclas
