MPLS Inter VRF route leaking
rajivmahuli1982
is it possible to leake a route from one VRF to another VRF on the Same PE. without having a RR in picture.
Rajiv Mahuli
mounir.mohamed
Level 7
Level 7
Dear rajivmahuli1982,
yes, but you must use the
import functionality of route-target and enable Border Gateway Protocol (BGP) on the router, This solution documented by Cisco in the below URL.
http://www.cisco.com/en/US/tech/tk436/tk832/technologies_configuration_example09186a0080231a3e.shtml
There is some changes in the below example as this is my self test for this document.
ip vrf VRF-A
rd 1:1
route-target export 1:1
route-target import 1:1
route-target import 2:1
ip vrf VRF-B
rd 2:1
route-target export 2:1
interface Serial1/0
ip vrf forwarding VRF-A
ip address 192.168.99.1 255.255.255.0
interface Serial1/1
ip vrf forwarding VRF-B
ip address 172.16.10.1 255.255.255.0
router bgp 1
address-family ipv4 vrf VRF-A
redistribute connected
address-family ipv4 vrf VRF-B
Best Regards,
Mounir Mohamed
Hi Mounir,
thanks for the reply but what if there is no MPBGP peering at all if its a standalone router will this still work ??
yes even if no BGP neighbor configured.
Please rate helpful posts.
Best Regards,
Mounir Mohamed
rajivmahuli1982
Thanks i got the answer
thanks for the document.
