Webvpn weird authentication issues
Apr 14th, 2008
Hi All,
I have just configured webvpn on a pair of asa5510's, the webvpn is now issuing a pop-up when I log in either to a group that authenticates locally on the asa of to a group that authenticates to a Radius server.
the Pop-Up is a User Alert in the form
https://**.**.**.**/+CSCOE+/useralert.html
(the pop-up is the same no matter what group I authenticate into.)
here is the webvpn config, any pointers to remove this would be GREAT
ciscoasa# sh run | beg webvpn
webvpn
enable outside
svc image disk0:/anyconnect-win-2.1.0148-k9.pkg 1
svc enable
tunnel-group-list enable
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol IPSec svc webvpn
group-policy Staff_Group_Policy internal
group-policy Staff_Group_Policy attributes
vpn-filter value STAFF_RULE
vlan 10
address-pools value Staff_DHCP
webvpn
url-list value Staff
file-entry enable
file-browsing enable
group-policy Student_Group_Policy internal
group-policy Student_Group_Policy attributes
vpn-filter value STUDENT_RULES
vlan 1
address-pools value Student_DHCP
webvpn
url-list value Students
file-entry enable
group-policy IT_Dept_Group_Policy internal
group-policy IT_Dept_Group_Policy attributes
vlan none
address-pools value IT_Dept_DHCP
webvpn
hidden-shares none
username ******* password *******
tunnel-group IT_Dept type remote-access
tunnel-group IT_Dept general-attributes
default-group-policy IT_Dept_Group_Policy
tunnel-group IT_Dept webvpn-attributes
group-alias IT_Dept enable
tunnel-group IT_Dept ipsec-attributes
pre-shared-key *
tunnel-group Students type remote-access
tunnel-group Students general-attributes
authentication-server-group STUDENT_RADIUS
authentication-server-group (student) STUDENT_RADIUS
default-group-policy Student_Group_Policy
tunnel-group Students webvpn-attributes
group-alias Students enable
tunnel-group Students ipsec-attributes
pre-shared-key *
tunnel-group STAFF type remote-access
tunnel-group STAFF general-attributes
address-pool Staff_DHCP
authentication-server-group STAFF_RADUIS
authentication-server-group (Staff) STAFF_RADUIS
default-group-policy Staff_Group_Policy
tunnel-group STAFF webvpn-attributes
group-alias STAFF enable
Overall Rating: 5 (1 ratings)
owillins Fri, 04/18/2008 - 10:20
Is user alert set in WebVPN mode?
ASA(config-webvpn)# no user-alert
ASA(config-webvpn)#
As for filtering Smart Tunnel traffic you will need to specify syntax as
such:
access-list temp webtype permit url smart-tunnel://x.x.x.x
mlatham67 Thu, 05/29/2008 - 13:40
Hi All
I Found that a reboot fixed my issue, but please make a note that a few weeks after we lost all access to cifs shares, the error was
Error Contacting Host
Please check bug CSCsl94183 and upgrade to asa803-12-k8.bin, this seems a lot more stable.
good luck.
schaef350 Tue, 09/17/2013 - 11:42
I found this thread while working on the same issue and figured I would update it to have accurate information:
I resolved this on our 9.1 ASA with something like this:
ciscoasa(config)# tunnel-group   general-attributes
ciscoasa(config-tunnel-general)# user-alert cancel
- Be sure to rate all helpful posts
Jatin Katyal Tue, 09/17/2013 - 21:51
CSCth21493
DOC: Multiple errors in ASA Command Reference for 'user-alert'
Symptom:
There are multiple errors in the ASA Command Reference regarding the 'user-alert' command. The most important one is, that from ASA version 8.2 onwards, the "no user-alert" command does not exist anymore, but has been replaced by the "user-alert cancel" command.
~BR
Jatin Katyal
**Do rate helpful posts**
