LMS3.0.1 crash
This morning I tried to get into CW and found that it had crashed. The page I was getting was Server Not REady. I tried to stop/start services but after about 30 minutes many parts did not come back like IPM and DFM. I noticed that Tomcat was using 400mb of memory and would not stop.
Is there a log that I can look at to find out what may have happened??
thanks
tony
pdshow is the status checker for the daemons that run everything on the system. If you can't determine what the state of the system is how can you troubleshoot ? Current status of the application daemons (never started, administraror shut down, running with busy flag set, etc) along with the log files can tell you exactly whats going on.
