Presence 6.0.1 on vmware box
Apr 14th, 2008
I try to install Presence 6.0.1 which my company buy in NFR bundle but experience problem with logging into just installed system - system is returning to login after I provide correct login and password. When I try to use ssh session - session is closed imediately after I provide correct creditentials. Web interface is not working at all. During cisco.com web searching I find follownig info regarding news in Presence v6.0.2:
• Support for VMWare usage of Cisco Unified Presence for lab, demo, and application development activities
you can find it here:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps6837/prod_bulletin0900aecd806f742d.html
Does it means that I can not successfuly install Presence 6.0.1 on vmware box? I can see that there are only upgrade files for Presence 6.0.2 for migrating from 6.0.1 but there is no possibility to install 6.0.2 using these files. How can I upgrade from 6.0.1 if I can not log into it?
Did anyone found the solution?
I appreciate any comments and suggestions.
BR
adrianic2003 Mon, 05/12/2008 - 18:41
I have got the same error first time when I have used same admin and useradmin usernames for cm60 and cups 6.0.1. Then I installed cups 6.0.1 again and use different admin and useradmin usernames than used for cm 6.0, and everything is working fine.
Kind regards,
A.
