Using ASA as SSL VPN client
Apr 14th, 2008
I have a few home users who have an ASA 5505 setup to use the EZVPN client to connect back to our headquarters, providing them "on-net" experience with real phones (instead of softphones). We're moving to a new hosted VPN service for traveling users, and the carrier is using an SSL VPN. Is there anyway to get my 5505s to connect to that service as well? Thanks.
ebreniz Fri, 04/18/2008 - 11:06
You can do the Auto Sign-on through Smart Tunnel. If you need SSL VPN - then choose webvpn & SSL VPN. If you need only webvpn, then use only webvpn. With regard to java info of port-forwarding, check if the list is being used in the group-policy.
While the smart tunnel now allows Java applet to work for some application, single sign on no longer works for it. Try creating a bookmark for the application and enable the ST option. This is a Smart Tunnel limitation.
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_configuration_example09186a008017b2a4.shtml
