AS5350 Remote Access Server Question
Apr 14th, 2008
Hello all. We need to setup a replacement remote access server. We have a isdn30 link and i'm looking at the AS5350XM to replace it. I'm a little confused to exactly what modules i need to impliment this. At the moment my shopping list is
AS5350XM AS5350XM Starter Kit (inc Chassis, MB, Def Mem) 1
AS535-DFC-2CE1 AS5350 Dual E1/PRI DFC card
is this all i need in order to get the AS5350XM to interface wit hthe ISDN30 and to receive dialup requests?
thank you in advance
Dean.
Makarand Chitale Mon, 04/14/2008 - 21:17
  • Cisco Employee,
Dean, if I understand correctly this Access server is for ISDN calls ONLY and not for digital modem calls - correct? Also you have a E1 connection and not T1?
If the purpose is only for ISDN calls then we are ok with the above parts.
More info on ordering:
http://www.cisco.com/en/US/prod/collateral/iad/ps501/ps6268/prod_brochure0900aecd802f8b88.html
Thanks, Mak
deanhoy Wed, 04/16/2008 - 05:50
Hello and ty for the reply.
the circuit is an E1 (isdn30 pri) as we are in the uk and it will be used for remote dialin. I will use a radius server for authentication of the remote users.
