ASA5510 setup
Apr 14th, 2008
hi there
i have an ASA5510 with the following setup:
e0 - outside interface-212.188.x.x/28
e1 - inside if - 192.168.3.x/24 into 2960sw pport 10 vlan 1-switchport access
e2 - dmz if - 172.16.x.x/24 into port 14 vlan 40 switchport access.
linux server plugged into port 14 vlan40 ip 172.16.x.x/24 g/w dmz interface.
windows server plugged into port 15 vlan1 ip 192.16.3.x/24. g/w inside interface
both the windows server and linux server can ping their default gateways but i cant seem to ping each server across the network or establish an ssh connection to the liinux box.
the sh route command on the asa shows the 3 connected n/w (outside,inside&dmz).
I can get to the internet fromt the inside thatis ok
when i try to ping the windows erver from the linuxbox i get network unreachable. below are the access lists:
access-list 106 line 1 extended permit tcp host 192.168.3.x host 172.16.10.x eq ssh (hitcnt=9)
access-list 106 line 2 extended permit icmp any any (hitcnt=148)
access-list 106 line 3 extended permit ip any any (hitcnt=122)
access-group 106 in interface inside
Any ideas? Plese help as im really baffled.
Thnkx
acomiskey Mon, 04/14/2008 - 07:26
  • Green, 3000 points or more
Try adding...
static (inside,dmz) 192.168.3.0 192.168.3.0 netmask 255.255.255.0
You will also need an acl applied into the dmz interface to allow the icmp reply traffic, or to initiate communication from the dmz to the inside.
access-list dmz extended permit icmp any 192.168.3.0 255.255.255.0
access-list dmz extended deny ip any 192.168.3.0 255.255.255.0
access-list dmz permit ip any any
access-group dmz in interface dmz
Hope that helps.
solpandor Mon, 04/14/2008 - 07:41
thanks for your reply.
it was more to do with the linux box rather than the asa. sorted out after i had to add a static route for the connected nw and also a default route
