ericgarnel Mon, 04/14/2008 - 07:32
  • Gold, 750 points or more
Yes. You will need some transceivers between the two. You can use either copper or fiber transceivers depending on what is available on your 3560 switch.
Either way, you will need to setup 2 ports on the 3560 to trunk dot1q with the controller.
You can use etherchannel on the switch if you put the controller in "lag" mode, or just leave the two trunks separate. If you do not use 'lag' on the controller, you will need to create 2 ap-manager interfaces and alternate the physical port priority between them
ajkhader123 Mon, 04/14/2008 - 07:40
Hello Eric,
Thanks for your quik response, can u please elobrate alternating the physical port priority.
ericgarnel Mon, 04/14/2008 - 07:48
When you configure the ap management interfaces under the controller | interfaces menu, you will specify the physical information as follows
port number
backup port
It will then list the port number setting as the active port. You will then reverse the physical port numbers on the other ap management interface. You could also use 'lag', but you will still need 2 ap management interfaces to get all 50 APs supported
ajkhader123 Mon, 04/14/2008 - 08:01
Eric,
Good explanation, adding to this is it possible to get an authentication from Active directory after loggin in with Radius authentication, like second level authentication, is it possible to do.
ajkhader123 Mon, 04/14/2008 - 08:52
Hey Eric,
Thank u so much for answering all my question, i would like to get continued this conversation, will get back with some queries later,
Abdul...
ajkhader123 Mon, 04/14/2008 - 11:37
Hi Eric,
Back again, is there any authentication method for AP's to get registered with WLC, like i am priming AP with WLC, when i connect other AP on the network it should not get registered, is there any authentication can be enabled for AP's not be registered with WLC.
ericgarnel Mon, 04/14/2008 - 11:49
Not sure what you are asking....
are you referring to wireless protection policies?
ajkhader123 Mon, 04/14/2008 - 12:10
I am adding only 5 AP on the network, i would like to know when any one try to add a new AP they should be promted for Authentication, is it possible to do so.
Scott Fella Mon, 04/14/2008 - 16:04
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
In an LWAPP install, you can authenticate an AP to a AAA server.
ajkhader123 Tue, 04/15/2008 - 06:12
This is for MAC, I would like to know how we create authentication B/W WLC and AP with WAP2-AES, this setup has been worked out in a wireless network.
