upgradinf from acns to waas
Apr 14th, 2008
hello,
i have a network module with acns image 5.57 on it. i havew been trying to upgrade it to waas 4.0.9b image but it has not been successful. does anyone know if it is possible to upgrade and how to go about it?
thanks
ebreniz Fri, 04/18/2008 - 11:18
  • Silver, 250 points or more
There is no "upgrade" (per say) from ACNS to WAASv4;that this is a complete reinstall of one application to the exclusion of
another. You can upgrade using a recovery CD (using the rescue image on CCO) or by using the ?copy? command from the CLI (using the binary image on CCO).
Here are the commands if you are not using the rescue cd.
copy cdrom install
http://www.cisco.com/univercd/cc/td/doc/product/webscale/waas/waas40/cmdref/execmds.htm#wp5404554
copy (http/ftp/tfp) install
http://www.cisco.com/univercd/cc/td/doc/product/webscale/waas/waas40/cmdref/execmds.htm#wp5405015
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v401_v403/command/reference/execmds.html
