Install CCA in HP DL140 G3
Apr 14th, 2008
I am try to install CCA Manager and Server 4.1.1 in a Server HP Proliant DL140 G3. The first time I put enter and I lose the keyborad and mouse. After that I found a bug (CSCsg98960) and the solution was to put "DL140" and after enter. OK now I have Keybord and mouse but the following error occurer "An error has occurred - no valid devices were found on which to create new filesystems. Please check your hardware for the cause of the problem"
Does anyone had the same issue?
mchin345 Mon, 04/21/2008 - 05:59
  • Silver, 250 points or more
Upgrades to 4.1(1) from previous versions are not affected by this bug.
Workaround
At the boot prompt that appears during installation, enter "DL140" and then .
Cisco Clean Access Installer (C) 2006 Cisco Systems, Inc.
Welcome to the Cisco Clean Access Installer!
- To install a Cisco Clean Access device, press the
key.
- To install a Cisco Clean Access device over a serial
console, enter serial at the boot prompt and press the
key.
boot: DL140
http://www.cisco.com/en/US/docs/security/nac/appliance/release_notes/411/411rn.html
DANIEL FERREIRA Mon, 04/21/2008 - 06:14
I put DL140 and the keybord issue was solved, but another error occurs - "An error has occurred - no valid devices were found on which to create new filesystems. Please check your hardware for the cause of the problem"
