DHCP Snooping and Port Channelng
Apr 14th, 2008
I have an 3560 running 12.2(40)SE IOS. This switch has two trunks in an etherchannel, connecting to a 6509 running 12.2(18)SXF12. Would I apply the *ip dhcp snooping trust* command on both uplinks that make up the EtherChannel?
Overall Rating: 5 (2 ratings)
Edison Ortiz Mon, 04/14/2008 - 09:58
  • Hall of Fame,
    Founding Member
Yes, you need to have trust enabled on switchports facing the DHCP server and to other switches.
HTH,
__
Edison.
Istvan_Rabai Mon, 04/14/2008 - 10:05
  • Gold, 750 points or more
Hi Mike,
You need to apply the "ip dhcp snooping trust" command on the port-channel interface, not on the trunks separately.
Cheers:
Istvan
Edison Ortiz Mon, 04/14/2008 - 10:08
  • Hall of Fame,
    Founding Member
On Layer2 etherchanneling, I always recommend mirroring the physical interface configuration with the logical interface configuration.
Actually, that's the way it works when you configure the etherchannel in the first place.
Istvan_Rabai Mon, 04/14/2008 - 10:43
You're right Edison,
Istvan
