QoS issue with access-lists
Apr 14th, 2008
I would like to create on a CE router a different QoS depending on 2 traffic types: web and the rest. The idea is to give to a less important application (the web) only 30% of the bandwidth.
My problem is that, with the following configuration, all the traffic match the highest priority access-list without matching the less priority access-list (0 match, even when the link is full).
Do you have an idea why ?
Jean-Baptiste
The config is the following one:
class-map match-any PRIOR_IN
match access-group name ALL
class-map match-any WEB_IN
match access-group name WEB
class-map match-any PRIOR_OUT
match ip dscp af21
class-map match-any WEB_OUT
match ip dscp af11
policy-map mark
class PRIOR_IN
set ip dscp af21
class WEB_IN
set ip dscp af11
policy-map etm
class PRIOR_OUT
bandwidth remaining percent 70
random-detect dscp-based
class WEB_OUT
bandwidth remaining percent 30
interface FastEthernet0/0
service-policy input mark
interface Serial0/0/0:1
service-policy output etm
ip access-list extended ALL
permit ip any any
ip access-list extended WEB
permit tcp any any eq www
Jon Marshall Mon, 04/14/2008 - 16:40
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jean-Baptiste
The problem is you are marking all traffic as dscp af21 because of the order in your policy-map mark. So change the order here ie.
policy-map mark
class PRIOR_IN
set ip dscp af21
class WEB_IN
set ip dscp af11
should be
policy-map mark
class WEB_IN
set ip dscp af11
class PRIOR_IN
set ip dscp af21
This way web traffic will be correctly marked with af11.
Jon
mheusing Mon, 04/14/2008 - 22:27
  • Cisco Employee,
Jon spotted the problem in your initial configuration and gave a working solution. A potentially more simple solution:
policy-map mark
class WEB_IN
set ip dscp af11
class class-default
set ip dscp af21
The class "class-default" is always present and has the definition of "match any", which means all the rest of traffic not matched in any other class before. This will achieve the same result as your ACL ALL matching all IP traffic.
Hope this helps! Please use the rating system.
Regards, Martin
