Route Switch Processor
Apr 14th, 2008
I'm after answers to a couple of questions on RSPs. I know the questions are pretty basic but I've only just come across these
If I understand correctly an RSP is an addon for a switch which allows it to "route". The RSP can send/receive routing protocol info.
If so what then becomes the difference between a switch with RSP and a true router from a routing perspective?
Can you still use ACLs with an RSP?
Can you still use features like VRRP?
Any info and links welcome.
Jon Marshall Mon, 04/14/2008 - 11:38
Paul
The RSP is the main processing engine for the 7500 router. It is not really an addon for a switch that allows it to route, more is the processing engine that includes the control plane and data plane for the 7500.
The control plane is responsible for establishing the routing table, CEF forwarding tables, peerings with other routers etc.
The data plane is responsible for forwarding the data. See attached sheet for more details
http://www.cisco.com/en/US/products/hw/routers/ps359/products_data_sheet09186a0080092013.html
What you may be thinking of as an add on card is an MSFC - Multilayer (thanks Stephen !) Switch Feature card which can be added to a supervisor module for a 6500. With an MSFC the 6500 can be a L3 switch, without it is a Layer 2 switch.
Jon
pointdee9 Wed, 04/16/2008 - 08:42
Sorry for the delay in replying.
Thanks for the info. You're right I was confusing the issue and a prod in the right direction was what I needed
