no Q921 or Q931 result on outgoing calls
Apr 14th, 2008
I have customer which I installed about a month ago. It is a SRST site hanging of a Callmanager 5.1 cluster. We had some issue getting them working, but it was running fine since then, untill now. they have 3 bri interfaces. it does not matter if I configure it for H323 or MGCP, I only get incoming debugs. Nothing outgoing. It is as if the calls never even reach the Gateway. This is the same for q931 and Q921. An ideas?
paolo bevilacqua Mon, 04/14/2008 - 16:38
  • Hall of Fame,
    Founding Member
Are these lines in hunt? Have you set isdn static-tei 0 ?
