Central DSP configuration for remote sites
Apr 14th, 2008
Is it possible to configure remote ip-phones to have resources from a central DSP farm from the CUCM 6.0?
I have remote sites with ip-phones, but only 4 DSP farms at 4 central sites (Cisco3845 full of PVDM2-64 cards, can the remote ip-phones get DSP resources from the Central-Sites DSP farms?
I'm using CUCM 6.0.
Overall Rating: 4 (1 ratings)
oscar.becerril Mon, 04/14/2008 - 14:20
Thanks. I already read the chapter, so, its is possible but not recommended.
Any configuration guide to do this kind of deployment using CUCM 6.0? (centralized DSP farms and remote phones)
matthewpage Mon, 04/14/2008 - 14:35
  • Bronze, 100 points or more
If you configure the DSP farm as you normally would and register it as a transcoder. That will be assigned to a media resource group (MRG) and that assigned to all the phones. Not sure if this is what you mean but that would mean all the phones use all the same resources.
I think the reason DSPFarms arent recommended is because the call will Unnecessary cross the wan.
Matt
