CDR Database Marked as Suspect
Apr 14th, 2008
This is 1P+7S cluster
CCM: 4.0(2a)es88
OS: Win2000sr7
CDRs are inserted into a database "MindDB".
Since last 2/3 days the CDRs are not being inserted and a event viewer error message is generated as
Error: 1105, Severity: 17, State: 2
Could not allocate space for object 'CallDetailRecordDiagnostic' in database 'CDR' because the 'PRIMARY' filegroup is full.
This is probably because CDR.mdf and CDR_LOG.ldf files have grown too large (9GB and 5 GB respectively).
Before we could remedy this, today morning an error message is received in event viewer
Error: 3314, Severity: 21, State: 4
Error while undoing logged operation in database 'CDR'. Error at log record ID (431923:4347:11).
After the above message the system is contineously generating following events
Error: 9001, Severity: 21, State: 1
The log for database 'CDR' is not available.
In enterprise manager, when clicked on CDR database, it generated an error message, telling the database is marked as suspect by recovery.
Any ideas how to remedy this
gogasca Mon, 04/14/2008 - 16:22
Here is a MS Article that explains how to get the database status reset.;en-us;180500
In short, run this from query analyzer
use master
exec sp_resetstatus cdr
Restart SQL Server
Verify that the database is not longer marked suspect.
Then run this from query analyzer.
If the trans log is large, perform the
following in query analyzer.
dump tran "cdr" with no_log
dbcc shrinkdatabase (cdr)
