04-14-2008 02:18 PM - edited 03-03-2019 09:33 PM
i have two cisco 4507 Switches one is acting as VTP server and switch 2 is client.
Both switch are trunk and i have confiugred the layer 2 Ether Channel on these two trunks.
I have around 7 vlans on switches and for each vlan i made a SVI and also configure these VLAN as HSRP.
switch 1 all vlan interfaces are active and switch 2 vlans are in standby mode. my active fw is connected
with switch one and failover is connected with switch 2.
user subnet is connected with vlan 7 and physical terminated on switch 1 ports 4/17 to 4/20 and having default gateway
of HSRP IP of VLAN 7, which is 172.28.31.163.
NOw problem is that, when switch one vlan 7 SVI goes down, and user is not able to reach any network.
though the gateway is virutal iP but still user is not able to reach anything.
Switch 1:
interface Vlan2
description ### To PDC-OUT-525-1 ###
ip address 172.28.31.65 255.255.255.248
standby 10 ip 172.28.31.67
standby 10 priority 250
standby 10 preempt
interface Vlan3
description ### TO PDC-Int-525-1 ###
ip address 172.28.31.81 255.255.255.248
standby 10 ip 172.28.31.83
standby 10 preempt
interface Vlan7
description ### To NOC###
ip address 172.28.31.161 255.255.255.224
standby 10 ip 172.28.31.163
standby 10 preempt
Switch 2:
interface Vlan2
description ### To PDC-OUT-525-2 ###
ip address 172.28.31.66 255.255.255.248
standby 10 priority 200
standby 10 preempt
interface Vlan3
description ### TO PDC-Int-525-2 ###
ip address 172.28.31.82 255.255.255.248
standby 10 preempt
interface Vlan7
ip address 172.28.31.162 255.255.255.248
standby 10 preempt
please tell me how to provide the redundency and how to configure it and what is missing in my configuration
04-14-2008 02:41 PM
Wasiimcisco,
I'm not sure if it as typo or not but the subnet masks are not the same for vlan 7. If you correct the mask on both switches things should work.
Mark
