BAT and update phone line
Apr 14th, 2008
I need to setup call forward no coverage on 1000 phone lines. How can I use Bat to do this? I checked the phone line update but it only allows you to enter one common number. Do I have to export and edit and import back?
Eric Krieger Tue, 04/15/2008 - 00:00
You didn't mention the version of the system.
Upto release 6 of Unified Communications Manager (CallManager) your options are limited (Export and Import, or manually).
As far as I remember/know with 6 you should be able to use an update file for the lines with BAT (Add/Update lines; overwrite existing configuration).
Eric
