IOS IPS ACL failure
Apr 14th, 2008
I am enabling IOS IPS on my router's fa0/1 interface and I am filtering out some IP addresses from this IPS as per the below config, however the IPS is still firing signatures when receiving mal traffic these IPs!!
Any ideas why?!!
Here is the IPS config:
ip ips sdf location flash:/128MB.sdf
ip ips signature 2004 0 disable
ip ips name MyIPS list 1
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
ip address
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address
ip ips MyIPS in
ip nat inside
duplex auto
speed auto
logging trap debugging
access-list 1 deny
access-list 1 deny
access-list 1 permit any
And here is the alarm which I see:
04-15-2008 01:12:56 Local7.Warning 130: *Apr 14 22:12:29.255: %IP_VFR-4-TOO_MANY_FRAGMENTS: FastEthernet0/1: Too many fragments per datagram (more than 32) - sent by, destined to
What made me more surprised is that I disabled the IPS on fa0/1 using the command "no ip ips MyIPS in" but the router kept giving me alarms!!
Any thoughts!!
R/ Haitham
didyap Fri, 04/18/2008 - 12:23
To create an access control list (ACL) filter for the deny actions on the intrusion prevention system (IPS) interface
rather than ingress interface, use the
ip ips deny-action ips-interface command in global configuration mode.
To return to the default, use the no form of this command.
Flow the URL for the further command for the IPS :
