Easy VPN on 1841
My name is Patrick Noel
I have a Cisco 1841. I configure a Site to Site VPN on it, which is working fine. I have static and dynamic NAT on it which are working fine also
Now I want to configure it as an Easy VPN Server so I can access my Corporate LAN from the outside.
I set it up. I can connect to the Easy VPN Server, but I cannot ping my internal network. I got either a reply from the server ip address instead of the internal ip that i am pinging or requet timed out.
I should mention that when I set up the Easy VPN Server, it modifies my Nat rules and it prevents me from seeing outside from the servers for which I had a static nat.
