removing secretary on CM
Apr 14th, 2008
hi experts,
when we remove the secretary's extension then those user's phone that is forwarded/diverted to this secretary,their calls will go to switch board.
Is there's a way to find out (b4 deleting the secretary's DN) to know who are linked to this secretary? So that we can adjust accordingly...
Overall Rating: 2 (1 ratings)
Jaime Valencia Mon, 04/14/2008 - 20:09
the only possible way to do so would be to review the numplan table and look under the CF fields in there to find out which phones are using that DN as CF destination
if this helps, please rate
redrobish Mon, 04/14/2008 - 21:20
thanks for the reply.
Any more ideas? how about when I want to generate some report on it?
Jaime Valencia Tue, 04/15/2008 - 06:45
unfortunately i told you about the DB since there are no reports on that =(
rob.huffman Wed, 04/16/2008 - 05:28
Hi Robert,
Sadly, as Jaime nicely noted there is no such Dependency report :( I'm guessing though that the phones that used to be covered by the Secretary whose DN is being removed are now being covered by someone else? If so, you could keep the DN alive (maybe a CTI Route Point) with a permanent Call Forward to the new Secretary/Admin. This way the calls will be routed appropriately.
Just a thought,
