HP Procurve and Cisco 4507
Apr 14th, 2008
Have a customer trying to connect a 4507 and a HP Procurve 4104. We have the cisco setup to trunk encapsulation dot1q and trunking the native vlan, but can't seem to get the HP to communicate. When the Cisco is port is setup as an access vlan port, everything works fine. Reason for trunking is customer has VMWare cluster connected to HPs and wants to change VLANs as needed, tested 1 server directly connected to the Cisco trunk port and it works great, can someone please help me out.
thotsaphon Mon, 04/14/2008 - 20:52
  • Gold, 750 points or more
Hi Christopher,
To make sure that the procurve switch,Cluster Server and Cisco switch have already been added the correct vlans.
To make sure that the procurve switch has correctly been configured the trunk port.
Just do a show vlan command on both switches.
Hopes this helps
Thot
b_ferguson Tue, 04/15/2008 - 04:24
Verified that both switches have the correct vlans configured...
francisco_1 Tue, 04/15/2008 - 04:48
when you have both switches in trunking mode, does the interface come up on the both switches (connected)?
b_ferguson Tue, 04/15/2008 - 04:50
yes, both switches show up on both ports. from what I have read and researched it looks like HP version of a trunk port is different from what Cisco calls a trunk port.
b_ferguson Tue, 04/15/2008 - 04:57
I want to say that we tried that last night with no luck but I'll have to go back and verify.
francisco_1 Tue, 04/15/2008 - 05:01
ok.
Let me know the outcome.
Francisco.
