04-14-2008 09:02 PM - edited 03-05-2019 10:23 PM
Is it possible to run an LACP etherchannel with a PAGP etherchannel on the same switch?
I have a HP switches on a blade server which only support LACP and my current environment only uses PAGP. I am testing this on a 3x 2970 with 12.2 IOS in a mesh.
04-14-2008 09:08 PM
yes u can run both LACP and PAGP on the same switch as is specific to the port channel.
Mahmood
04-15-2008 12:16 PM
Hi Jason,
You can select the channel-protocol when you create the ether-channel on the interface level similarly to this:
interface fa1/1 - 4
channel-protocol pagp
channel-group 1 mode desirable
So the "channel-protocol [pagp | lacp] is not a global config command.
The "port-channel load-balance" command is a global config command. You can't configure load-balancing on a per interface basis, it is valid on the whole switch.
Cheers:
Istvan
