3825 support for HWIC-2FE
Apr 14th, 2008
I asked someone at Cisco about the number of HWIC-2FE cards supported by the 3825 (they said 4 - one in each HWIC slot). This seems to be contradicted by the HWIC data sheet - which says only 2 HWIC-2FE cards can be used in the 3825. Which number is correct? (2 cards [4 FE ports] or 4 cards [8 FE ports)? Thanks much!
thotsaphon Mon, 04/14/2008 - 22:07
Hi doug,
It should be used by all hwic slots.But when I saw this document then I would use only maximum 2 cards per chassis because the document say you can only have 6 layer3-FastEthernet ports.
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd80581fe6.html
Thing is the HWIC-1FE and HWIC-2FE the minimum level is Cisco IOS 12.4(15)T.
It should be hardware limitation,I thought!
Hopes this helps
Thot
vaisharm Mon, 04/14/2008 - 22:08
Hi Doug,
Below are your options on a Cisco 3825:
4 x 1-Port Fast Ethernet HWIC (ie. 1 to 4 HWIC-1FE may be installed in Slot 0 to slot 3)
OR
2 x 2-Port Fast Ethernet HWIC (ie. 1 to 2 HWIC-2FE may be installed in Slot 0 to slot 3)
Source:
http://www.cisco.com/en/US/docs/routers/access/interfaces/ic/hardware/installation/guide/fe_hwic.html#wp1051838
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd80581fe6_ps5853_Products_Data_Sheet.html
HTH,
~Vaibhav
