Catalyst 3750-24FS
Sushil Kumar Katre Sun, 04/20/2008 - 23:51
The wavelength depends on the optical standard. Since the switch you are referring to comes with 100Base-FX standard the wavelength used will be 1300nm.
Minimum Wavelength - 1270nm
Maximum Wavelength - 1380nm
Fiber Type should be MultiMode and the core size can be 62.5 or 50 micron.
>> Sushil
