04-14-2008 11:44 PM - edited 03-15-2019 10:04 AM
Hi all, i try to upgrade my 4.1(3)sr1 cluster but DMA refuse to migrate the DB because of the following amazing error:
[07:06:29 PM] --- End -- Exporting CCM DB
Failure- Zimbabwe network locale needs to be replaced with a newer version before upgrade.
This message is preventing the DB migration process. There is no Zimbabwe locale available for download.
Have anyone already seen the before ?
Thanks for your appreciate help.
Julien.
04-15-2008 12:18 AM
Seems i have to installed the "combined" network locale available for 4.1(3)sr1. I am installing it, i will update the post for the DMA process.
Julien.
04-29-2008 03:54 AM
Combined network contains the locale. Works fine now.
Julien.
12-03-2009 01:13 AM
Julian,
When you fixed this issue, did you simply install the 4.1 Cisco IP Telephony Locale Installer (cm-locale-combined_network-4.1.3.4200.exe) and that was it?
I assume this had no impact to the phones, do you now get extra drop down options in the phone locale option?
Jed
12-04-2009 12:04 AM
Hello, Jed, yes i installed the file you mentioned. Regarding others options in locale parameters, i have not tested before upgradinf the cluster through DMA process.
Julien
12-21-2009 07:39 AM
Did you have nay issues with the locale instal? We're getting the following error:
Cisco Unified CallManager local server name was returned empty!
Ensure that the local server's name is correctly configured in SQL Server before retrying installation.
This is described in the locale instal guide as:
However, exactly what needs updating in the SQL database isn't described! Any clues?
The customer has tried creating a publisher by taking the publisher disk and inserting it in a new server, but not connected to a network, so I'm not sure if this is impacting it in any way.
Jed
07-09-2010 09:03 AM
this link shows you how to do this:
http://www.cisco.com/en/US/products/sw/custcosw/ps1001/products_tech_note09186a0080130cdf.shtml
hope this is useful to anyone visting this post
G
02-01-2012 10:08 AM
Did you install the "cm-locale-combined_network-4.1.3.4200.exe" on all the servers PUB & SUBS? I was told by TAC that I could just try doing it on the PUB and it should satisfy DMA but it is still failing with the same error.
-andy
