wlc 526 + ap 521 using dhcp on dlink but cannot get an ip
Apr 15th, 2008
i setup a wlc 526 with 2 521 aps, all of them are connected to the dlink DI-624+ ethernet router which is configured as DHCP. The wireless seems ok, but when a pc connected to the wireless network it was unable to receive dhcp from the dlink router.pls help me to solve this problem
drolemc Mon, 04/21/2008 - 06:34
Since the wireless part works fine between the WLC 526 and the 521 APs, the problem is with the other router which acts as a DHCP server. Check if DHCP has been configured correctly, or try using a different DHCP server.
Michael Ciulei Fri, 05/30/2008 - 02:40
At the wlc526 http page, go to controller->advanced->DHCP->deselect Enable DHCP Proxy.
For me it works fine.
shoulhafiz Sun, 06/01/2008 - 23:02
thanx man but that doesn't work for me.Finally I just configured a linux box as a dhcp server and everything is working just fine.thx.
dennischolmes Wed, 06/11/2008 - 04:30
Guys,
Some lesser valued dhcp servers will not accept dhcp by proxy as it is delivered by a controller on behalf of the client. To solve this issue then use this command at the cli
config dhcp proxy disable
This will allow your PCs to get a dhcp address from a dhcp server that does not support dhcp by proxy.
