Mobile phone directory
Apr 15th, 2008
Hi all,
I have a corporate directory for our internal numbers (Extensions) which is working fine.
I have CCM 4.1 integrated with AD.
Now I would like to create a similar corporate directory for Mobile phones numbers, is there any way that I can easily accomplish that.
Is it possible to write a simple xml file for this?
agiaccone Tue, 05/06/2008 - 08:27
I'm writing a simple web service to provide this in my last UC deployment. It will be a matter of weeks, and I'll publish it as freeware.
If you can't wait for it, here's a simple explanation :
You should create a web application (the server-side language it's on you) that returns to the client (ip phone) not HTML but the Cisco subset of XML (http://www.cisco.com/univercd/cc/td/doc/product/voice/vpdd/cdd/5_0/5_0_1/ipphsv/ip503ch2.htm)
Your web app should ask on the first page the name of the contact to look for, make an ldap query, and then return the XML with the contact's data.
Hope this helps,
Alberto
mnour401917_2 Tue, 05/06/2008 - 16:53
Hi Alberto,
Thanks for the reply, I will try it. and if i can't get it working i will wait for your Web service.
Cheers
