04-15-2008 04:06 AM - edited 03-14-2019 02:05 AM
What is meant by overriding VRU Settings?
Arpit
04-15-2008 04:58 AM
Arpit,
When you check this option, for example, if you have set up in the IVR script that a prompt is not interrumplible and you check the script in ICM as interrumpible, the VRU script is interrumpible though you have set it up as non interrumplible.
Hope this helps,
Juan Luis
04-15-2008 05:16 AM
04-15-2008 05:30 AM
Sorry,
I think that you were referring to the VRU properties in Configuration Manager.
I have never used this node. I have used QM or IPIVR.
Juan Luis
