Site too Site with same NAT
Apr 15th, 2008
I have to connect two offices using 1841 routers . I just have an issue both the sides are behind a single subnet 192.168.2.0 NATTING. The issue is how will be the router able to manage that which IP exist at which site.When ever i try to configure Site to site VPN it stuck on Intresting traffic . Kindly specify me a better solution.
Overall Rating: 3 (1 ratings)
imranraheel Wed, 04/16/2008 - 12:31
the issue is i m over internet and the example is for policy based nat can u have any clue
Jon Marshall Wed, 04/16/2008 - 23:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
deleted - posted twice
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Imran
Doesn't matter whether you are over the Internet or not, the principle is still the same.
PBR - not sure what you are asking. Do you want to use PBR for your VPN setup ?
Jon
banso_boy Fri, 04/25/2008 - 03:12
Jon,
I think from my understanding the static route will make the different sites communicate but will not be able to access the internet.
I am facing a similar problem as I want to build site to site vlans by extending the idea of the link you sent.
Any suggestions on how I should work on this?
