ASA5505 SIte-to-Site VPN
rvr_76bg
Hello Guys,
I am experiencing a problem with Site to Site VPN between 2 ASA/s 5505. It seems very simple task, and it is, but I am missing something. I just want the communication between both Internal LAN/s connected on both devices to be UP. I see the IPSec tunell is UP but I cannot ping from LAN to LAN. I attach the configurations of the two devices. Everything was configured by the GUI (VPN Wizard).
Any help will be really appriciated, this is a bit ugrent.
Thank you in advance.
acomiskey
Level 10
Level 10
Remove the access list on your inside interfaces.
no access-group inside_access_in in interface inside
no access-group inside_access_out out interface inside
Also, do you mean for your inside interface at DN to be dhcp?
No, DN inside will not be a DHCP either server or client.
