WLSE SQL1032N No start database manager command was issued
Apr 15th, 2008
i have a problem with my WLSE device.
it seens like db2 database fails to start.
[email protected]:diag all
DIAG: IMAGE
*** PASS: Software image verification passed. ***
DIAG: BIOS
*** Drive model does not require BIOS patch. ***
DIAG: DMA
Checking disk for DMA errors *** PASS: NO DMA IO errors found. ***
Checking disk sectors for errors ...*** PASS: NO disk sector errors found. ***
DIAG: DB2CLEAN *** PASS: No dump files found. ***
DIAG: DB2VERIFY *** FAIL: Cannot connect to DB2. Integrity verification failed. ***
DIAG: SERIALNO *** Serial Number -???????? ***
[email protected]:service status
Process= TFTP
State = Program started - No mgt msgs received
Info = Application started by administrator request.
Process= WirelessSvcMgr
Process= WLSEjobvm
State = Running but busy flag set
Info = WLSEjobvm started.
Process= WLSEFaults
State = Running normally
Info = WLSEFaults is ready.
Process= CDPbrdcast
Process= WLSEIdleServer
Process= WLSERepository
Process= HaMibDaemon
Process= WebServer
Process= Tomcat
Process= ExcepReporter
Process= PerfMon
snmpd (pid 1854) is running...
Database test failed
FAIL Version and product query result was:
SQL1032N No start database manager command was issued. SQLSTATE=57019
Any idea??? is it possible to start the database manager without restoring the database?
Thank you in advanced.
gmarogi Mon, 04/21/2008 - 10:10
  • Bronze, 100 points or more
This happens when the database of WLSE is corrupted. Use " reinitdb " command to reinitialize the database. Then try to stop the service for 5 mins and start again.
Trending Topics - Security & Network
