LMS 2.6 Topology Services Very Slow
Apr 15th, 2008
I have LMS 2.6 with current patches installed, I have discovered 2366 devices. I have 109 User Defined Topology Groups.
When I try to open a topology group it takes at a minimum 10 minutes to open just the list, not the map...are there performance tuning parameters I can configure? Has this been seen before?
Well the more groups you configure, the more memory it consumes on the client. 100 User Defined Groups is the top supported configuration so tac will suggest you loose 9 of them to begin with. You can edit the class file to add more local buffer space, but it wont improve the performance. Your best bet is to toss the biggest baddest box you can afford at it as a sacrifice.
sirbaughmf Tue, 04/15/2008 - 07:54
I am hosted on a Sunfire V440 with 8G memory and 20G swap, server performance seems to be ok, running about 50% cpu and 3G memory...
My setup also includes SSO between three servers, my Master server doesn't seem to have the performance issue with topology services, just my slaves.
I'm wondering if there might be an issue with that, causing slowness on the slaves????
sirbaughmf Wed, 04/16/2008 - 11:00
I'm still seeing these performance issues,has anyone seen this? Anyone with suggestions?
thanks, Marcie
