04-15-2008 08:22 AM - edited 07-03-2021 03:43 PM
I am in the process of designing a Wireless solution to connect 2 separate buildings that are hard to wire. In the design, I have a central building that will home all of the networking devices including, wireless bridge, and the gateway. This is the building where I will put the central bridge and a directional antanna. My question is, how should I connect the other 2 buildings to this central building?
Would it be with one cental bridge and antanaa to connect the other 2 buildings (P2MP)? Would this allow full-duplex for each connection?
Would it be with 2 cental bridges and 2 directional antannas to connect to the 2 separate buildings (P-to-P) to allow full-duplex for each connection?
Thanks for the prompt response,
sK
04-21-2008 11:24 AM
Wireless is always a Half Duplex connection. If you are concerned about speed you can have 2 point - point connection. But the Bridge at the centre needs to have dual Radios. If you are concerned about the cost You can go for point - Multipoint with single Radio in the Bridge at the centre.
04-24-2008 02:23 AM
Hi SK,
How far are these buildings from the central location? Based on that we can calculate the link bandwidth with p2mp connection.
For this you can look for 1300 G Bridge at the central location and 1200/1300 G radio bridges at the remote location.
If you are looking for p2p then have a look at 1240 AG accesspoin which can be configured as a bridge. Have A radio connectivity with one building and B radio connectivity with the other. At the remote buildings you can have 1200 A radio AP configured in bridge mode and 1231G AP configured in bridge mode respectively.
-> Sushil
