ACS 4.1 questions
Apr 15th, 2008
I executed the csutil -d to get a copy of the dump.txt for some scripting. It asked me for a password so I hit <enter> because I do not want it password protected. At this point, I cannot copy the file to anohter computer but yet I can copy it to the same server. Any ideas of how to get this done?
Can I do a dump that is not password protected?
dpatkins Tue, 04/15/2008 - 12:07
My apologies to all. I have one more question for you about the ACS 4.1 Appliance. I need to get gain access to the passed authentication logs and to be able to copy them to a test server that we have set up. Can this be done? How does one gain access to the 4113 SE Appliance?
Thank you,
Jagdeep Gambhir Wed, 04/16/2008 - 07:54
Blank password should not be a issue here. I just tried it and was able to move that dump file across the network.
If you are trying to import that dump to different acs then we need to have password protection.
