Easy Firewall questions ASA 5505
Answered Question
Apr 15th, 2008
Hi, I am new to Cisco devices in general. I decided to pick up an ASA 5505. Well, I have been pretty stumped for weeks by it's setup. The configuration should be easy. I intend to place it as a firewall between our inside network and our outside network. The outside interface IP will be 64.200.x.x, whereas the inside IPs will be 10.1.1.0. I got it working to the point that I can browse the Internet from behind it fine, but I cannot seem to get mail messages into my mail server at IP 10.1.1.15 (actually a security appliance that forwards to the server). I would like to NAT all my inside connections to appear as the outside interface on the internet, and would like incoming mail redirected to 10.1.1.15. I also have heard about a command, "no inspect protocol smtp 25", but cannot seem to get this command to work properly. Here is what I have tried with results:
Result of the command: "no fixup protocol smtp 25"
WARNING: 'no fixup ...' command not processed because no global policy-map is enabled
It says I don't have a global policy map. Have I messed something up there?
I am going to post my config as a reply. Also, I plan to later set up some VPNs and some of the settings are still in the config. Tell me if that's a problem. Please tell me some of the things I am doing wrong here. Maybe I should wipe it and start fresh using what I know now?
Correct Answer by sundar.palaniappan about 9 years 1 week ago
Chris,
The address is reversed in the static and your ACL needs to permit smtp traffic to the global address of the mail server. Can you make the following changes to the config, do a 'clear xlate' and test.
no access-list outside_access_in extended permit tcp any host 10.1.1.15 eq smtp
access-list outside_access_in extended permit tcp any host 64.200.x.x eq smtp
static (inside,outside) tcp 10.1.1.15 smtp 64.200.x.x smtp netmask 255.255.255.255
static (inside,outside) tcp 64.200.x.x smtp 10.1.1.15 smtp netmask 255.255.255.255
If the 64.200.x.x address you are using for the mail server is the outside interface address of the ASA substitute the IP address with the command 'interface outside' in both ACL and static configuration.
Sundar
Overall Rating: 5 (1 ratings)
itccv0822 Tue, 04/15/2008 - 09:20
Result of the command: "show running-config"
ASA Version 7.2(3)
hostname ciscoasa
domain-name default.domain.invalid
enable password w9.E89J6LPOGR3zI encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 10.1.1.1 255.255.255.0
ospf cost 10
interface Vlan2
nameif outside
security-level 0
ip address 64.200.x.x 255.255.255.248
ospf cost 10
interface Vlan3
no forward interface Vlan1
nameif dmz
security-level 50
ip address dhcp
ospf cost 10
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
passwd 2KFQencrypted
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list outside_1_cryptomap extended permit ip 10.1.1.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip 10.1.1.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list outside_access_in extended permit icmp any any
access-list outside_2_cryptomap extended permit ip 10.1.1.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list outside_3_cryptomap extended permit ip 10.1.1.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list outside_4_cryptomap extended permit ip 10.1.1.0 255.255.255.0 192.168.5.0 255.255.255.0
access-list outside_5_cryptomap extended permit ip 10.1.1.0 255.255.255.0 192.168.0.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any outside
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 64.200.223.xxx 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 10.1.1.0 255.255.255.0 inside
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer 74.8.140.xxx 64.209.221.xxx
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map 2 match address outside_2_cryptomap
crypto map outside_map 2 set pfs
crypto map outside_map 2 set peer 74.212.201.xxx
crypto map outside_map 2 set transform-set ESP-3DES-SHA
crypto map outside_map 4 match address outside_4_cryptomap
crypto map outside_map 4 set pfs
crypto map outside_map 4 set peer 64.60.171.xxx
crypto map outside_map 4 set transform-set ESP-3DES-SHA
crypto map outside_map 5 match address outside_5_cryptomap
crypto map outside_map 5 set pfs
crypto map outside_map 5 set peer 64.209.221.xxx
crypto map outside_map 5 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 10.1.1.2-10.1.1.100 inside
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
prompt hostname context
Cryptochecksum:3a296
Correct Answer
sundar.palaniappan Tue, 04/15/2008 - 10:01
  • Green, 3000 points or more
Chris,
Sundar
itccv0822 Tue, 04/15/2008 - 10:07
Thanks for the quick reply. I am actually wiping it to factory config because as I posted I realized how messy it had become. So then I will set it up as you indicated. I will post my cleaned up config on here shortly for you guys to double check then test tonight and tell you first thing in the morning how it went. Maybe I will be able to run the no fixup command after I restore it to factory defaults.
sundar.palaniappan Tue, 04/15/2008 - 10:23
I don't see the global policy map in your configuration and it appears you may have removed it. Moreover, I believe 'no fixup protocol smtp 25' is on by default in ASA and if you enter the 'fixup' ASA would convert that to the equivalent policy map configuration. Anyway, you would see all that stuff since you are resetting it to factory default. Let us know how it goes.
Sundar
itccv0822 Tue, 04/15/2008 - 10:37
Thanks, Here's the (much) cleaned up config, can you tell me anything else?:
: Saved
ASA Version 7.2(3)
hostname ciscoasa
domain-name companionhospice.pri
enable password xxx
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 64.200.xxx.xxx 255.255.255.248
interface Vlan3
nameif dmz
security-level 50
ip address dhcp
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
passwd xxx
ftp mode passive
access-list outside_access_in extended permit tcp any host 64.200.xxx.xxx eq smtp
pager lines 24
mtu outside 1500
mtu inside 1500
mtu dmz 1500
arp timeout 14400
static (inside,outside) tcp 64.200.xxx.xxx smtp 10.1.1.15 smtp netmask 255.255.255.255
route outside 0.0.0.0 0.0.0.0 64.200.xxx.xxx 1
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 10.1.1.2-10.1.1.254 inside
class-map inspection_default
match default-inspection-traffic
parameters
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
Cryptochecksum:xxx
: end
sundar.palaniappan Tue, 04/15/2008 - 10:49
Looks good to me. As I said before if you are using the outside interface IP as mail server's global address then use the word 'interface outside' in ACL and static command in place of the IP address.
Sundar
itccv0822 Tue, 04/15/2008 - 10:56
Yes, my mistake. Like this?:
: Saved
ASA Version 7.2(3)
hostname ciscoasa
enable password xxx
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
interface Vlan3
nameif dmz
security-level 50
ip address dhcp
passwd xxx
ftp mode passive
access-list outside_access_in extended permit tcp any interface outside eq smtp
pager lines 24
mtu outside 1500
mtu inside 1500
mtu dmz 1500
arp timeout 14400
static (inside,outside) tcp interface smtp 10.1.1.15 smtp netmask 255.255.255.255
route outside 0.0.0.0 0.0.0.0 64.200.223.49 1
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
Cryptochecksum:xxx
: end
itccv0822 Tue, 04/15/2008 - 11:27
Alright I will test tonight and tell you how it goes right away. Thanks for your help.
sundar.palaniappan Wed, 04/16/2008 - 07:59
No problem. Glad I could help.
Thanks for the rating :-)
itccv0822 Sun, 12/21/2008 - 11:48
Hi, Thanks for all your help. I am a little farther on in the configuration of the site to site VPN. I am working on it, but in the meantime, I posted a new post for any feedback:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=Remote%20Access&topicID=.ee719fe&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc29ff8
If you could help with that one it would be a life saver. I can't really test without going into the office after hours, so any feedback is great.
