¿ The acl for "dmz access to inside" can slow performance ?
Apr 15th, 2008
Guys,
If you si any problems with the ACL, I ask that you please let me know at once.
My users are reporting latency with the web server after I implemented this rule. Please advise. Thanks.
access-list 109 extended permit tcp host 172.16.8.22 host 192.168.54.235 eq 8009
access-list 109 extended permit udp host 172.16.8.22 host 192.168.54.235 eq 8009
access-list 109 extended permit udp host 172.16.8.22 host 192.168.54.198 eq domain
access-list 109 extended permit udp host 172.16.8.22 host 192.168.54.196 eq domain
access-group 109 in interface DMZ
So, in what issues the acls can produce a slow access or performance ?
access-class is used to define, generally by source-address, which remote systems are allowed to connect via telnet or ssh to your device.
access-group specifies instead an ACL for packets allowed to traverse an interface, independently from the fact these are destined to the router or not.
An ACL applied outbound (with access-group out) will filter only traffic that goes through the router but will not filter traffic that originates on the router.
