Can wireless client associate AP by AP loading but not signal strength
Apr 15th, 2008
Hi all,
Can wireless client associate AP by existing loading of AP but not by wireless signal strength?
Thanks & Regards,
leon.mflai Fri, 08/15/2008 - 10:00
Hi Eric,
WLC has a feature called "RRM" Radio Resource Managment. One of feature within this feature set is called "Aggressive Load Balancing". Aggressive Load Balancing is function provided "power" and "channel" are dynamic.
If "Aggressive Load Balancing" is turned on, WLC will monitor the loading of each AP. If there is a AP overloaded, WLC will signal this LAP to reduce its power level. Therefore, the behavior of WLAN client association is adjusted.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
