how do you sucessfully change 4 port etherchannel
Apr 15th, 2008
How do you reconfig an etherchannel from trunk mode on to desirable? have 2 6509's with an active etherchannel config'd using sup720 ports 5/1,5/2 and 6/1, 6/2. slot six is redundant card on both mls'.
Overall Rating: 4 (1 ratings)
mohammedmahmoud Tue, 04/15/2008 - 11:30
You can simply change the mode under the port-channel interface:
interface Port-channel x
switchport mode dynamic desirable
BR,
Mohammed Mahmoud.
Br4xt0n41 Tue, 04/15/2008 - 11:39
this is an active channel, if i config one side won't it drop before i can config the other side?
mohammedmahmoud Tue, 04/15/2008 - 11:50
Technically speaking, there should be no problem, since as a DTP rule a trunk can be established if one side is desirable and the other side is either Trunk, Desirable or Auto, accordingly i don't believe that there is going to be any service disruption.
BR,
Mohammed Mahmoud.
